I find it interesting that although the OEM rear wheel choices for the 718 vary from 9.5 x 18 to 10.5 x 20, the rear tire size remains unchanged at 265 mm?
Looking at the info supplied on the TireRack web site, it appears that my OEM tire (Eagle F1) in 265/35-20 is best fit on a 9.5" wide wheel.
For competition, Cayman/Boxster drivers routinely stuff a 255/35-18 on the front 8.5" wide wheel. Note that TireRack shows that size tire to best fit a 9" wide wheel. However, speaking from first-hand experience, I can tell you that it fits and works well on an 8.5" wheel.
So, my question is how wide a tire can we fit to the 10.5" wide rear wheel? Specifically, a 10.5" x 19" wheel?
Looking again at the TireRack info for the OEM tire, that data says a 295/35-xx is best fit on a 10.5" wide wheel. The 295mm tire has a 1.2" wider section width then the stock tire so it would roughly extend 0.6" more on each side. Looking at my rear suspension and wheel opening, I don't see how there would be any interference issue at all. In fact, the tire I'd prefer to run is a 305/30-19. However, its section width is 12.3" versus the stock section width of 9.5" on the OEM 265/35-20 tire.
According to TireRack, the 305mm wide tire is best fit on a 11" wide wheel but as with the 255mm tire on the front 8.5" wide wheel, I believe the 305 will fit the 10.5" wheel just fine.
My concern is would the 305mm tire rub the strut or worse yet, the fender? Note that the OEM 265/35-20 has a diameter of 27.3" while the 305-30-19's diameter is 26.2" so there would be 0.55" additional clearance vertically.
Comments???
Comments???
