1 - 2 of 2 Posts
Anybody with experience with the 9500ci install on a Boxster? I have been leveraging all the information for the Caymans that currently posted which is very good for the Boxster. I have run into one area that isn’t obvious and that’s getting the rear sensor routed to the main unit. It’s not as simple as routing the cable under the carpet since it has a soft top in the way.
I found a wire bundle going from the back left fender towards the front and what appears to be the bundle coming out behind the left door. I tried to fish a wire through either way and was not successful getting very far from either side.
Check to see if anybody has done an install on a Boxster and can provide guidance before I start taking things apart.
Thanks,
1 - 2 of 2 Posts
