Sorry. I never thought to take pictures as it was the most intense operation I've undertaken on a car. Engine swaps on my Boxster are considerably easier.
The pump was leaking fluid as quickly as it could be added to the reservoir.
I did go through the fender. The alternatives are engine-out, or removing the front end. Even so, getting those 11-year-old Torx bolts on the pulley to release their hold required grinding heads off two of the three anyway.
Other pitfalls include the extremely tough access to the rear mounting bolt--and it's a Torx, too!
Getting the turbo pipe back on was challenging. It's hard to get leverage to push it back in place. Use plenty of silicon spray to help it. I also heated it a little.
Then an additional annoyance was the o-rings supplied with the pump for the return lines were just too big. And don't forget to get that new high-pressure o-ring for the bottom output. That little thing is $6, and trust me, you don't want to have to go back in there to replace it.
You will need to pull the radiator fan and housing. This improves access immeasurably. It isn't easy, but the hardest element is just getting it by the radiator hose. It's armored, though, so you won't hurt it squeezing it by.
Now, the kicker: I know why the pump failed. When I started the car, a puddle formed under the rear axle. It's leaking and draining the system.
One last tip is to replace the serpentine belt while at this. You don't want to do this again in your lifetime.
