Porsche Prophet
Just took in my 2013 Boxster for its 20,000 mile service (don't ask about the cost - that is another new thread in itself!) and was told that the rear tires were just about gone...
Running the following sizes - Front - 235/40ZR19 Rear - 265/40ZR19 the brand is GOODYEAR and they are the original tires...
The question are - replace the rear two only?
If I replace the rear two only - do they need to be the same original GOODYEARS?
Can I get two from a different brand (Pilot Super Sports)? and run them with the original GOODYEARS on the front?
Your thoughts?
Super Moderator
You can do whatever you want but the recommendation is:
If the fronts are good, yes
YES, and the same N-spec number. For example, if the fronts are N0, then the rears must be N0. If you can't get N0, then you should get 4 new tires, like all N1.
NO
See http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=26&currentpage=38
PCA Member and DE Instructor
Another rear tire replacement question that has been covered numerous times on here. Why?
Porsche Prophet
Discussion Starter #4
Thanks for the fast reply...I kinda knew that was the situation - but just wanted to bounce it off the "experts"
The best handling is always with the same tire on all 4 corners. I would always recommend to match and on your car the rears are always going to wear much faster on the back. I would put the Goodyears on this time and then look at options the next time when you need to replace all 4. If I can help let me know.
Porsche Prophet
Discussion Starter #6
Hey - thanks again for the info...my intention is to replace the rears with the original Goodyear's as soon as I get the resources together - probably next month - I will give you a call...
