1 - 20 of 29 Posts
The purpose of this thread is to assemble a gallery of dyno charts for the 981 Cayman range (inc. GT4, GTS, S, base model) along with supporting information.
A key aim is to provide reliable baseline performance related information including dynometer results (under various conditions) for the 981 series. Ideally and where possible contributors should identify the source of performance data and where dyno derived, the type of dyno used to collect the data. The conditions at the time of the run and the type of transmission e.g. manual or PDK are useful supporting information. If possible, fuel type should be specified using AKI RON or MON notation (note AKI = Ron+MON/2).
1) 981 Cayman GT4 manual (Auto Sport), T ~ 14 to 19 degrees C, P ~ 977 hpa, peak WHP 325PS @ 6300rpm MAHA
note: Upper red line calculated torque (Nm), lower red line calculated HP (PS), blue line is WHP (PS), green line is run down loss.
Source: AutoSport Magazine Ausgabe 5/2015
2) Cayman S PDK, T 13 - 22 degrees C, P ~ 997 hpa, peak WHP ~ 280 PS @ 6700rpm, MAHA (see note below graph)
Please note, I rechecked the original source of the graph directly above and it is from the previous gen Cayman S
Source: https://www.youtube.com/watch?v=Fz3RozESilY
Discussion Starter #2 (Edited)
3) 981 Cayman GTS PDK average of 5 runs, T ~ 20 degree c, P not known, peak WHP is 280hp to 285hp from 6000rpm to 7700rpm
note: 1 run yields a peak value over 300WHP, if this is discounted average peak WHP is ~ 285hp
note: torque and power are derived at the wheel and displayed in the graph as WHP and WTqe
note: averaging via best fit curve
Comparison between GTS and GT4, all results are at the wheel
Note: GTS data average of 5 runs (see post above)
Note: GT4 data average of 3 runs (same dyno as above but over different days)
Discussion Starter #4 (Edited)
Peak WHP
a) GT4 ~ 320WHP ~ 325WPS ~ 239RWKW
b) GTS ~ 280WHP ~ 284WPS ~ 209RWKW
c) CS ~ 270WHP ~ 274WPS ~ 202RWKW
d) peak losses ~55HP to 65HP relative to AFWHP.
Discussion Starter #6 (Edited)
FACT FILE SECTION
CAYMAN 981
Engine - 2706cc
Max Power - 202kW 275PS 271HP @ 7400rpm
Max Torque - 290Nm from 4500 to 6500rpm
WHP - 215HP 218PS 160kW (min.WHP derived from reported frontal area, drag, top speed, t ~15 degrees c, rolling resistance ~0.012)
HP loss - 56HP (from above and relative to HPAFW)
Top Speed (PDK) - 266kmh/ 264kmh
0 to 100kmh/ 62mph (PDK) - 5.7s/ 5.6s
Sport chrono PDK 0 to 100kmh - 5.4s
0 to 160 kmh/ 100mph - 12.9s/ 12.8s
Sport chrono (PDK) 0 to 100kmh - 12.5s
Manual fifth gear 80 to 120kmh - 8.0s
80 to 120kmh PDK - 3.6s
Weight manual - 1330kg
Weight PDK - 1360kg
Length/Width/Height/Wheelbase - 4380mm, 1801mm, 1294mm, 2475mm
Brakes - 315mm front, 299mm rear, vented and cross drilled, four pot fixed callipers front and rear
Wheels - 8x18 57 offset front, 9x18 47 offset rear
Tires - 235/45x18 f, 265/45x18 r
cd - 0.30
Power:weight - 152W/kg (m) 148W/kg (PDK)
Fig 8 test - 24.3s @ 0.8g average (Motortrend)
1/4mile - 13.9s at 102.7mph (Motortrend)
Nordschleife -
Blyton Park - 1:07.7s (EVO)
Magny Cours - 1:26.4 (MotorSport)
CAYMAN S 981
Engine - 3436cc
Max Power - 239kW 325PS 320HP @ 7400rpm
Max Torque - 370Nm from 4500 - 5800rpm
WHP - 259HP 263PS 194kW (min.WHP derived from reported frontal area, drag, top speed, t ~ 15 degrees c, rolling resistance ~0.012)
HP loss - 61HP (from above and relative to HPAFW)
Top Speed (PDK) - 283kmh/ 281kmh
0 to 100kmh/ 62mph - 5.0s/ 4.9s
Sport chrono (PDK) 0 to 100kmh - 4.7s
0 to 160 kmh/ 100mph - 10.8s/ 10.7s
Sport chrono (PDK) 0 to 100kmh - 10.5s
Manual fifth gear 80 to 120kmh - 6.5s
80 to 120kmh PDK - 3.0s
Weight manual - 1340kg
Weight PDK - 1370kg
Length/Width/Height/Wheelbase - 4380mm, 1801mm, 1295mm, 2475mm
Brakes - 330mm front, 299mm rear, vented and cross drilled, four pot fixed callipers front and rear
Wheels - 8x19 57 offset front, 9.5x18 45 offset rear
Tires - 235/40x19 f, 265/40x19 r
cd - 0.3
Power:weight - 178W/kg (m) 174W/kg (PDK)
Fig 8 test - 24.1s at 0.83 average (Motortrend)
1/4mile - 12.7s at 109.7mph (Motortrend)
Nordschleife - 7:55.0s Walter Rohrl
Blyton Park - 1:05.5s (EVO)
Magny Cours -
Hockenheim Short - 1:13.6 (AutoSport)
CAYMAN GTS 981
Engine - 3436cc
Max Power - 250kW 340PS 335HP @ 7400rpm
Max Torque - 380Nm from 4750 to 5800rpm
WHP - 272HP 276PS 203kW(min.WHP derived from reported frontal area, drag, top speed, t ~15 degrees c, rolling resistance ~0.012)
HP loss - 63HP (from above and relative to HPAFW)
Top Speed (PDK) - 285kmh/ 283kmh
0 to 100kmh/ 62mph - 4.9s/4.8s
Sport chrono (PDK) 0 to 100kmh - 4.6s
0 to 160 kmh/ 100mph - 10.6s/ 10.5s
Sport chrono (PDK) 0 to 100kmh - 10.3s
80 to 120kmh PDK - 2.9s
Weight manual - 1345kg
Weight PDK - 1375kg
Length/Width/Height/Wheelbase - 4404mm, 1801mm, 1284mm, 2475mm
Wheels - 8x20 57 offset front, 9.5x20 45 offset rear
Tires - 235/35x20 f, 265/35x20 r
cd - 0.31
Power:weight - 186W/kg (m) 182W/kg (PDK)
Fig 8 test - 23.8s at 0.94 g average (Motortrend Ignition)
1/4mile - 12.8s at 111.8mph (Motortrend Ignition)
Nordschleife -
Blyton Park - 1:05.2s (EVO)
TopGear track - 1:21.6s (TopGear)
Magny Cours - 1:24.2 (MotorSport)
Hockenheim Short - 1:12.8 (AutoSport)
CAYMAN GT4 981
Engine - 3800cc
Max Power - 283kW 385PS 380HP @ 7400rpm
Max Torque - 420Nm from 4750 to 6000rpm
WHP - 306HP 310PS 228kW (min.WHP derived from reported frontal area, drag, top speed, t ~15 degrees c, rolling resistance ~0.012)
HP loss - 74HP (from above and relative to HPAFW)
Top Speed - 295kmh
0 to 100kmh/ 62mph - 4.4s
0 to 200 kmh - 14.5
Manual fifth gear 80 to 120kmh - 5.5s
Length/Width/Height/Wheelbase - 4438mm, 1817mm, 1266mm, 2484mm
Brakes - 390mm front, 390mm rear, vented and cross drilled, six pot fixed callipers front and four pot fixed callipers rear
Wheels - 8.5x20 61 offset front, 11x20 50 offset rear
Tires - 245/35x20 f, 295/30x20 r
cd - 0.32
Power:weight - 211W/kg (m)
Nordschleife - 7:42.0 Christian Gebhardt
Magny Cours - 1:20.28 (MotorSport)
Hockenheim Short - 1:10.1 (AutoSport)
Source The Cayman, The New Cayman GT4 published by Dr. Ing. h.c. F. Porsche AG. (2014 and 2015)
Note: Given the lack of abundant high quality dyno data a WHP value can be calculated on the besis of drag limited top speed - see WHP calculated in the panel above and summarised below: The WHP is calculated from data reported by Porsche and AutoSport magazine, the key assumptions beyond these facts are air temperature, air density, the energy content of the fuel and a reasonable estimate of rolling resistance. The calculation also takes into account the mass of the driver and fuel. On this basis and using reported engine power specifications and tolerances (Porsche power output error is 0% to +5%, engines rated below published outputs are rejected during the factory QA/QC process). The calculated WHP is the amount of WHP needed to overcome the effects of both rolling resistance and drag. This assumes the cars reported top speeds are drag limited. The numbers presented below are realistic baseline rear wheel horsepower values:-
Cayman 981 WHP Ranges (rear wheel horsepower)
981 Cayman - 215HP - 228HP
981 Cayman S - 259HP - 275HP (MAHA 987 S ~ 276RWHP)
981 Cayman GTS - 272HP - 288HP
981 Cayman GT4 - 306HP - 325HP (MAHA range 297RWHP to 320RWHP)
see note above
For reference using the same calculation outlined above the 981 Boxster S has a calculated RWHP 0f 252HP
(MAHA ~ 248RWHP)
Discussion Starter #8 (Edited)
Manual Gear Ratios 981 Cayman (base model)
Gear ratio kmh mph
(1)---3.67---70----44
(2)---2.05--125----78
(3)---1.46--176---110
(4)---1.13--228---142
(5)---0.97--265---166
(6)---0.84--306---191
Final reduction axle ratio 3.89
Note: Speed calculated at 7700rpm with 20 inch wheels and 265/35 tires for a diameter of 694mm.
PDK Gear Ratios 981 Cayman (base, S, GTS)
Gear ratio kmh mph
(1)---3.91---79----49
(2)---2.29--134----84
(3)---1.65--187---117
(4)---1.30--237---138
(5)---1.08--285---178 (approx drag limit GTS)
(6)---0.88--359---219 (effectively overdrive)
(7)---0.62--497---310 (effectively overdrive)
Final reduction axle ratio 3.25
Note: Speed calculated at 7700rpm with 20 inch wheels and 265/35 tires for a diameter of 694mm. PDK ratios for the 981 series are the same as the PDK ratios found in the Carrera S. The final reduction axle ratio in the Carrera S is 3.44.
Manual Gear Ratios 981 Cayman (S, GTS, GT4, not base Cayman)
Gear ratio kmh mph (7700rpm) kmh mph (4000rpm)
(1)---3.31---77----48 ...............(40---25)
(2)---1.95--130----82 ...............(68---42)
(3)---1.41--180---113 ...............(94---59)
(4)---1.13--225---141 ...............(117--73)
(5)---1.08--268---167
(6)---0.95--314---196
Note: Speed calculated at 7700rpm with 20 inch wheels and 295/30 tires for a diameter of 686mm.
Note2: Gears 1 to 4 at 4000rpm within the typical range of the first section of the torque curve prior to full activation of variocam plus.
Note3: Gears 1 to 4 ideally situated for daily driving and effective short shifting.
http://press.porsche.com/vehicles/2014/2014_Cayman_Technical_Specifications.pdf
Discussion Starter #9 (Edited)
Figure 8 tests
Car-------time-s------g(avg)----lateral g
918--------22.2-----1.06---------1.12
911GT3----22.8-----0.96---------1.11 (991)
911GT2----22.9-----0.90----------NA (lateral g not reported)
911T4S----23.0-----0.93---------1.04 (991 Turbo S AWD)
911GT3RS-23.4-----0.92---------1.08 (997)
981CGTS--23.8-----0.94---------1.04
981CS-----24.1-----0.83---------1.04
991S-------24.1-----0.82---------1.03
911GT3----24.2-----0.81---------1.02 (997)
981C-------24.3-----0.80---------1.06
997GTS----24.4-----0.79---------1.00
987CR-----24.5-----0.82----------1.01
Note: Cars that post times below 25s are considered very good, times below 24s are considered outstanding and times below 23s exceptional. Source: Motortrend instrumented tests, using OEM tires.
Reference Cars
BMW M4 - 24.2s at 0.84g average and 0.98 lateral
Jaguar F type - R - 24.4s at 0.82g average and 0.94 lateral g
Lotus Evora - 24.2s at 0.80g average and 1.0 lateral g
Alfa 4C - 24.3s at 0.84g average
Discussion Starter #11 (Edited)
Additional information - Fact File as generated by Motor Trend
Cayman GTS
Cayman GT4
Fig 8 test - 23.5s (Motortrend Ignition)
1/4mile - 12.3s at 115.2 mph (Motortrend Ignition - episode 138)
Figure 8 tests
918---------22.2-----1.06----------1.12
991GT3-----22.8-----0.96---------1.11
911GT2-----22.9-----0.90----------NA
991T4S-----23.0-----0.93---------1.04
997GT3RS--23.4-----0.92---------1.08
981CGT4--
23.5-----NA-----------NA
981CGTS--
23.8----0.94---------1.04
9914S------23.9-----NA------------NA
981CS-----24.1----0.83---------1.04
997GT3----24.2-----0.81---------1.02
981C------24.3-----0.80--------1.06
987CR-----24.5------0.82--------1.01
Discussion Starter #12 (Edited)
Relative Torsional Rigidity
Konigsegg Agera 58,000 Nm/deg
Cayman S/GTS 40,000 Nm/deg
Audi R8 40,000 Nm/deg
Lexus LFA 39,130 Nm/deg
Aventador 35,000 Nm/deg
Ferrari 458 33,120 Nm/deg
Jaguar F - Type coupe 33,000 NM/deg
Porsche 991 911 30,359 Nm/deg
Mazda RX8 30,000 Nm/deg
Aston Martin Vantage coupe 27,273 Nm/deg
Pagani Zonda F 27,000 Nm/deg
Ford GT40mk1 17,000 Nm/deg
Dodge Viper 11,400 Nm/deg
What's the source on the torsional rigidity number? I've seen it before, but I believe it's incorrect...
Discussion Starter #14 (Edited)
Hi Pete
Drives 2014 Porsche Cayman S - Test Review 2014 Porsche Cayman S (original source)
Review: Porsche Cayman S 2013 - Page 1 | Luxury Insider - The Online Luxury Magazine
"Even then, we were floored when we discovered just how much more rigid the two-seater Cayman was to be: its impressive 42,000 Nm/° torsional rigidity surpasses that of the 991 Coupe's 30,400Nm/º, but it never seems overly stiff for daily-road use and really comes into its own on a perfectly paved circuit"
and
Excellence Magazine, September 2015, cites Porsche Cayman body shell torsional stiffness at 41,900 Nm/degree and claims it to be "the highest of any non-carbon-fiber tub production car"
So the Cayman may be even stiffer than first thought
Discussion Starter #16
Erratum - manual gear ratios for S/GTS/GT4 - gears 5 and 6 were incorrectly transcribed - gear 5 = 0.95 and gear 6 = 0.81
Discussion Starter #17 (Edited)
Discussion Starter #18 (Edited)
Car and Driver Test Results
981 GT4
Zero to 60 mph: 4.1 sec
Zero to 100 mph: 9.0 sec
Zero to 150 mph: 22.9 sec
Rolling start, 5-60 mph: 4.7 sec
Top gear, 30-50 mph: 6.8 sec
Top gear, 50-70 mph: 6.0 sec
Standing ¼-mile: 12.3 sec @ 117 mph
Top speed (drag limited, mfr's est): 183 mph
Braking, 70-0 mph: 151 ft
Roadholding, 300-ft-dia skidpad: 1.01 g
981 CAYMAN GTS (Manual)
Zero to 100 mph: 9.8 sec
Zero to 130 mph: 17.2 sec
Zero to 150 mph: 25.9 sec
Rolling start, 5-60 mph: 4.9 sec
Top gear, 30-50 mph: 7.0 sec
Top gear, 50-70 mph: 6.2 sec
Standing ¼-mile: 12.5 sec @ 113 mph
Top speed (mfr's est): 177 mph
Braking, 70-0 mph: 160 ft
Roadholding, 300-ft-dia skidpad: 1.04 g
981 BOXSTER GTS (PDK)
Zero to 100 mph: 10.1 sec
Zero to 130 mph: 18.2 sec
Zero to 150 mph: 28.2 sec
Rolling start, 5-60 mph: 4.6 sec
Top gear, 30-50 mph: 2.7 sec
Top gear, 50-70 mph: 3.0 sec
Standing ¼-mile: 12.6 sec @ 112 mph
Top speed (mfr's est): 173 mph
Braking, 70-0 mph: 152 ft
Roadholding, 300-ft-dia skidpad: 1.05 g
981 CAYMAN S (PDK)
Zero to 100 mph: 10.0 sec
Rolling start, 5-60 mph: 5.1 sec
Top gear, 30-50 mph: 2.8 sec
Top speed (drag limited): 173 mph
Braking, 70-0 mph: 146 ft
Roadholding, 300-ft-dia skidpad: 0.99 g
981 CAYMAN (Manual)
Zero to 60 mph: 5.7 sec
Zero to 100 mph: 13.7 sec
Zero to 130 mph: 31.7 sec
Rolling start, 5-60 mph: 6.6 sec
Standing ¼-mile: 14.2 sec @ 102 mph
Top speed (drag limited): 166 mph
Braking, 70-0 mph: 148 ft
1 - 20 of 29 Posts
