One might think of the way the windshield installers remove a windshield - which is glass set into a silicone adhesive bead. They push a piece of wire through the silicone and then pull it around to cut the silicone. I would think if you started at the narrowest point in the headlight - you might be able to saw through the silicone seal, then work the wire around.Wow great job ! I would be scared taking a dremel to the headlights. Wondering if there is any other method to removing the covers
