1 - 10 of 10 Posts
I checked the corner weight of my 2014 Cayman S. Let me preface the below numbers by saying that I think the factory engineering of this car is fantastic right out of the box, with perhaps the actual nuts and bolts alignment which I recently had corrected at my dealer. Anyway, here are my numbers. I used a Longacre computer scale set, and I am fortunate to have my own two post lift. All scale pads leveled to within 0.10 degree of each other.
Stock, sway bars connected, no ballast:
LF 677 RF 679
LR 887 RR 877
LR-RF cross was 50.2%, LF-RR was 49.8% total weight 3120
Stock, sway bars disconnected, no driver ballast (virtually no change):
LF 687 RF 676
LR 881 RR 886
Now the good news, 240 lbs drivers ballast, sway bar disconnected:
LF 741 RF 706
LR 965 RR 923
LF-RR Cross was 49.8%, LR-RF Cross was 50.2%, total weight 3333 lbs
As you can see, no worries about the weight distribution of this car!
Just thought I'd share
Doug
No, 240 lbs of bagged concrete mix, 4-60 lb bags evenly distributed in seats
You put bags of concrete mix on your seats? :confused:
Thanks for the information. Now I don't have to do that myself. ;)
Yeah, one bag was only open just a little, I think I can get the cement out with a little muriatic acid. Was that a bad thing:crazy:
Just use some lye to neutralize the acid and you'll be good to go!
Lol. Guess no one got the joke
Interesting. Those are very good numbers out of the box!
Amazing results for a factory street car!
1 - 10 of 10 Posts
