Coil packs will give you some crazy error messages. I was at NCM doing track days last year and started getting ABS failure messages while on the track. I finally parked the car, but then on the way home to Louisville started to lose power and had to pull off the interstate. I let the car sit awhile, restarted it, and was able to get home. Good luck!
Rob
95% this is a coil gone bad. Easy to DIY. #6 will probably go on you as well, so buy a spare.
engine lwarning ight on car shaking.
Did you ever followup on this from the exact same conversation that you started about this three weeks ago? Coil packs were suggested at that time and its not going to just magically go away. You need to take the car to someone that can conclusively diagnose any misfire codes and and change them out for you if you dont plan to attempt it yourself.
