1 - 8 of 8 Posts
2014 Boxster Base
I have a 981 Boxster Base. Under the nose in front of each front tire there are a pair of rubber air guides that divert air/debris to the sides of the tires. The outside air guide on the passenger side got sheered off. I have the replacement part which has 6 tabs that just snap into some slots on a plastic plate that may be part of the wheel well liner. I cannot get those tabs to snap in place.
Anyone have any experience here.
thx Mike
put some water soluble lubricant (KY jelly for example) on them, insert, then wash off with a hose.
PS, I came to this idea after I did this without the lube :mad:
What's the part number? I was unable to find it myself last time and one of mine is coming apart. Thanks.
2014 Boxster Base
991-504-792-00 Flow Device
this is the right hand guide, driver’s side as viewed from rear. I believe the same guides are used for both wheels but don’t hold me to it. The Porsche parts diagrams could be better.
There are two guides for each side. But I think there is two part numbers, each side of the car gets 1each of both part number.
1 - 8 of 8 Posts
