Hi,
My first gen 987.1 3.4L spun a rod bearing with less than 50K miles. Using good summer tires but not R compounds. Religious oil changes, running good Motul oil. Had a deep sump pan and pickup installed. Did oil analysis regularly with no signs of any trouble. Car ran great until the sudden rod knock and failure which happened while doing a casual 40MPH. A bit of a turn but nothing high-G at that point. Only about 10K miles on that engine were mine. The crank, cylinder walls, just about everything on the bottom end were pooched.
I'm getting a new 3.4L motor, but reviewing the forums, these things seem to be manufactured out of cheese for how often they have issues. Before this new motor goes in, I'd like to do whatever I can to ensure this never happens again.
I know there are a lot of posts on this forum about oiling mods. Certainly the deep sump / baffled pan which I had. Accusump might have worked, but people here have had failures with those installed. Just too much lag time?
My mechanic believes this is a heat soak issue on the #6 bearing, not necessarily oil starvation. And that the oil layer breaks down. I trust what he's saying, but that sounds to me like a design flaw that won't be addressed by the usual oiling mods.
1.) Has anyone had these failures with a dry sump? This seems like overkill, and I'm just not sure the sump was the issue.
2.) I'm told building the motor fixes the issue. I know the rod bolts can stretch. I suppose clearances can be ensured, but why else does building these motors prevent the spun bearings? On it's own, it doesn't seem to address the main issue that the bearing loses oil pressure
3.) Is there some engine mod I'm missing? Crank oil porting or extra squirters or something that a builder of these engines needs to do to during a rebuild to fix the oiling issue? I've not found descriptions for what needs to be addressed internally during a rebuild.
Thanks for any tips, especially if you've had this engine rebuilt. I trust my mechanic to rebuild the engine right if he cracks the new one open. But I want to better understand the options as I frankly no longer trust these engines to stay in one piece.
