1 - 20 of 21 Posts
Stupid College Kid
Pulled mods and stock parts from my 987.1 Cayman S. Located in Kirkland, WA. Everything is used except the power steering cooler kit. More photos available upon request. Make me an offer for the stock interior pieces, otherwise just gonna throw away
1. EBS Racing X51 Baffle (Used ~15k mi.) - $175 shipped
*Modified to fit Mantis Deep
4. Stock Shifter (Used ~70k mi.) - $100 shipped
6. L & R Door Hinges 997.555.381.01 & 997.555.382.01
7. L & R Door Handles 997.555.461.00 & 997.555.462.00
8. L & R Upper Door Covers (These were drilled out of my original door so i could put RS door pulls in. Don't know if anyone has a use for them)
9. 1 Door Bowden cable
Very interested in the deep sump if it comes with everything necessary for install (I know I'll need to get new seals).
Since it has been modified, will it only work with the 996 swirl pots now?
Could you provide a shipping quote to 30533?
Stupid College Kid
Discussion Starter #4
The deep sump comes with everything to install. There arent any new seals you'll need to get just gasket maker. It can work without the swirl pots. The wind windage tray may not be as effective without the swirl pots covering the holes otherwise oil will go right through. Could ask mantis to send you another windage tray or water jet your own. I'll get you a quote later today.
Sent from my SM-N950U using Tapatalk
Stupid College Kid
FYI I just made an edit to the ad. I found out the cables I have are for a 5 speed not a 6 speed.
EBS Racing X51 Baffle - $225
*Modified to fit Mantis Deep sump
Is this modified for the 1.2L or 2.0L Mantis deep sump? Is there anything else required to make it work?
Thx
Stupid College Kid
Discussion Starter #16
I has the 2.0L deep sump pan. The bottom of the baffles were cut around the perimeter so it could sit flush with the windage tray. This worked for the 2.0L but I believe it would work for the 1.2L as it looks like they both have the same windage trays, just different pan depths.
Stupid College Kid
Discussion Starter #20
Bump, updated prices and added some stock interior pieces i still have. I also re-added my NM200 Numeric Shifter Cables, they don't have a PN but i confirmed with Daniel Geberth that these are NM200 only made for the 987/986 5spd.
1 - 20 of 21 Posts
