The front shock on my 987.1 Cayman needs to be replaced.
I have the option to buy used Cayman R front shocks but I was wondering if those would fit a 987.1 Cayman S and if they'd be equivalent to Cayman S OEM or stiffer? Looking at this thread it would seem like shocks are different between the Cayman R and S but was looking for those confirmations:
The car has H&R springs with stock shocks today and I already find the ride extremely stiff for the road, despite the car being 85% track at this point I still like to drive it elsewhere.
At the moment I was contemplating to replace the front shocks with Bilstein B6 which should be a bit better than stock for the track but not going towards much stiffer options, going with used Cayman R shocks would be a lot cheaper... (there is no used cayman S shocks in my area)
many have described the Cayman R as having a good balance performance wise. Described as Cayman in permanent sport mode. I haven't tried them - I'm running B6 at the moment. B6 is not really comfort oriented but I put up with it for the performance. of course YMMV.
How old are the shocks? if they're too high mileage they may not be at their best.
Shocks, springs rates and ride height are very important to the handling of the Cayman 987. You can cobble together a lot of aftermarket stuff for cheap, but you will get cheap effects. Upgrade your suspension to Ohlin R&T coilovers. You can beat these coilovers to death and they still perform as described on the Ohlin web page. Spring rate of 400 lbs/in f and 458 lbs/in in the rear. You can drop your ride 35mm without affecting the springs or shocks. If you go for the dropped look, be prepared to add a rear adjustable toe link bar due to the toe in adjustments is not attainable without an adjustable link. Also, you will need adjustable down links to get a corner balance to work without preloading your swaybars. You have successfully reduced the weight transfer both across your car as well as f to r with this reduced ride height.
The Ohlin's have 20 clicks of rebound and compression adjustment, which actually do change the dynamics of the suspension a lot. I have used 3 clicks from stiff in f and 4 clicks in the rear on smooth tracks with good success. For the daily drives, I have used 15 clicks from stiff for both f & r to 10 clicks f and r just depending on the tire/wheel weight setup. I use all the track width I can get on my car, so the wheels are leveraged by the offset a lot. What that means is the tires are at the edge of the wheel well, almost hitting the top lip on compression.
For my daily drives, I use the OEM 18 inch rims with Michelin PS4's in 255/35/18 f and 275/35/18 r. This combo seems to work well, but I do get some rear tire grip/traction issues with full throttle. Most likely a 285/35/18 maybe a better choice. The total weight of the tires and OEM wheels seem to work best with the Ohlin rebound setting around 10 for both f and r. Lighter weight wheels and tires opens up the options much more to track work, canyon drives and back country bumpy roads.
@Apex1 Wait, so you're saying that you can't drop 987 (.2 in my situation) on springs without a toe link extension for a proper toe? What toe are you running front/rear? thx
