Howdy Folks,
Pulled the car out of the garage recently for a mid-winter drive on a cold (30F) sunny day. After about 20 mins of normal gentle driving, I got hard on the throttle for about 20 seconds. As soon as I lifted off the throttle, the car went into reduced power mode with nearly every warning lamp on the dash lighting up. I pulled over, shut off the engine said a prayer in German (bitte starten) and cranked her back up. All seemed normal and she drove home just fine, although I refrained from any further hard accelerations.
The car, 2011 Cayman S PDK. plenum, GT3TB, fabspeed headers and cats, and Cobb protune from Fabspeed. It's mostly a track car with ~80K miles and 15-20 track days. Last year I had to replace the PDK transmission and its only been driven about a 1000 miles since.
See the Durametric error codes below. While the camshaft sensor seems to be an obvious potential failure, I wonder with all the other codes if what I experienced was a momentary CAN bus communications problem or a sign of a ECU going bad. I can clear the codes no problem nothing comes back, but I haven't taken it back on the road yet.
My worry is I have a track event in 6 weeks and have no desire to be on the track and experience this. I'll have my mechanic check it also but has anyone seen anything like this issue before?
Engine Controller
P0010 Intake Camshaft Driver
P0010 No signal/communication
P0010 Value below lower limit
P0015 Implausible signal
Transmission-PDK
C401:U401 CAN Fault, engine
C418: U0418 CAN fault, brake (this code has been in the unit since I've owned the car)
PSM
C200 Control module fault engine electronics (drive)
Airbag -P0SIP
C152: Communication PSM control unit (drive)
C150 Control unit communications engine electronics (drive)
Cornering Lights
C203 Fault steering wheel electronics
8022 Compression angle sensor
Engine Controller
Transmission-PDK
PSM
Airbag -P0SIP
Cornering Lights
