1 - 3 of 3 Posts
Hoping someone knows that this steel cable is, near where the bottom of my top anchors, on the passenger side of my ‘05 Boxster. I can’t see a ball this would connect to and can’t see anything similar on the driver’s side. It was recently serviced to have the driver’s side top transmission gear replaced so maybe just not re-connected. Thanks!
272212
272213
It's located just below the right side of the rear window on the inside of the top. If you have the owner's manual it should describe removing the cable when the top is put in service mode.
-RobT
Sent from my Pixel 3 using Tapatalk
-RobT
Ah, yes - I recall seeing that while researching the aforementioned transmission gear. Thanks! I’ll dig in there tomorrow and snap it back in place.
1 - 3 of 3 Posts
