1 - 8 of 8 Posts
· Registered
Here is my write up for removing the cluster and replacing your gauge faces:
I completely disconnected that battery for this project.
First, remove the trim piece below that gauge cluster. This piece has the leather cover connected to it. To remove pull back towards you with some force. I grabbed mine with a microfiber Towel:
Speedometer Vehicle Car Tachometer Steering part
Next, you will see two Torx screws (T20). I highly recommend using a magnetic bit and a magnetic retriever for removing and installing these pieces. This is usually a place where my hands would shake and I'd drop a screw into the abyss:
Speedometer Vehicle Steering part Light Car
Next, gently pull the cluster towards your. On the left hand side there will be a wire with a connector. The connector has a clip/mechanism that you will simply release by pushing it towards the front of the vehicle:
Hood Motor vehicle Light Steering part Automotive design
Hand Automotive tire Bumper Finger Gadget
Now, head to your workbench with the Cluster and your Torx set.
On the back there will be 6 Torx screws. Remove them and set them them in a jar or magnetic bowl for safe keeping.
I recommend you photograph the needle position for a reference when putting each needle back on.
There will be easily removable/liftable clips on the bottom of the cluster. Loosen them and then begin carefully prying at the top of the cluster to separate the cluster.
With the cluster apart, pull straight up on each needle to remove.
Now you will remove the existing gauge face. The gauge face is held in primarily by 4 plastic rivets that sit where each needle you just removed was.
Gauge Motor vehicle Car Yellow Automotive design
Font Eyewear Circle Gas Automotive design
A plunger or extractor would be best here, I pulled mine out with needle nose pliers. I broke a bit off each one, however it didn't take away from their integrity and it will be hidden by the needles. These also won't interfere with the needles.
Guitar accessory Finger Circle Audio equipment Automotive lighting
With the old Gauge Face removed, lay your new face on the cluster. I did wash my hands here before handing to prevent any oils from getting on the face. Push North on the face to "snap" in the uppermost clips and guide the outer notches of the face into the left and right slots.
Font Rectangle Art Circle Games
Tree Paint Circle Font Plant
Now you can reset the 4 plastic rivets into the needle holes. Line up the needles and insert them.
I took this opportunity to polish and clean the outer plastic of the cluster. It had some nasty swirls on it:
Musical instrument Idiophone Cookware and bakeware Gas Metal
Now you simply reassemble the cluster, put in the 6 Torx screws, and take the cluster back to the vehicle.
Eyewear Gas Goggles Audio equipment Circle
Insert the electrical connection and refasten the clip.
Insert the 2 Torx 20 screws to secure the cluster, again taking care not to drop one into the dash.
Reconnect your battery and enjoy!
Car Speedometer Vehicle Motor vehicle Wheel
Speedometer Vehicle Trip computer Car Odometer
· Administrator
Outstanding DIY with excellent photos.. makes me want to do this to mine.. wonder how much a white faceplate costs..
Reactions: ELCID86
· Administrator
Thank you! I paid about $215ish, with shipping, on that German site. I love the look.
That's not awful.. I thought I saw prices around $600, wonder if I went to the wrong website...
· Registered
I just replaced my faces plus the two side LCD's as well. He and I sourced our faces from: Heiler Tachodesign Here's what mine looked like:
Which are the original and and which are the new ones? Looking at the pics, everything is the same except for the oil temp dial. Seems like the tan one is Fahrenheit and the white is in Celsius.
· Registered
The tan one was original. The original tan overlay had shrunk and looked terrible. You could barely read the speedometer numbers. Celsius or Fahrenheit was an option. Decided to go with Celsius because German cars should be in metric! Also 40-80-120 looks better than 100-175-250, and matches what’s on my Mercedes S124🤣
· Registered
Understand your reasoning, wasn’t sure if it was intentional or a mistake, as I am in the process of going for the same mod and the website is confusing enough in English, so didn’t want to make any errors in the ordering process. What I would desire from them is a color chart, since they list numerous background color choices and my first choice was going to be white but that could change if I could see samples of the other color offerings. I will attempt to reach them by email for a palette to choose from. Good luck with your mod.
1 - 8 of 8 Posts
