1 - 3 of 3 Posts
I recently acquired a 991S Cab. The turn signal flasher relay is too quiet and I have to look too see if it is on, or if I left it on. Does this car have a traditional flasher relay? If so where is it located? If not any ideas on how to increase the click volume level?
Sent from my XT1058 using Tapatalk
RTFM!
Maybe you don't have one as there is only one per vehicle issued.
Using your TFT display stalk or roller if you have a multifunction steering wheel, go to Settings and in there you will find Audible for LOW, MEDIUM and HIGH if I remember correctly. Choose the sound level you want.
While in this Menu, SET all the settings to your preference. Well worth the effort to learn and use.-Richard
If you can't make it work PM me with your number and time to call and I will walk you through it.
1 - 3 of 3 Posts
