1 - 2 of 2 Posts
Are you getting the full potential out of your 991.2 Carrera?
Whether your car is completely bone stock, or you have made multiple modifications, our 991.2 Carrera Tune achieves this by optimizing the engine’s air/fuel ratios, timing, boost pressure, and more.
We have put in countless hours testing on the Dyno to ensure the highest quality results. As you can see in the Dyno Chart below, done by a third-party vendor, this tune provides performance gains of +74 WHP and +129 ft/lbs of TQ.
This upgrade requires you to send us your ECU for re-programming. The ECU will be tuned within 24-48 hours of receiving it and Fabspeed will then ship back the ECU for a very simple reinstallation; no modifications to the vehicle are necessary.
ECU Tunes are available for completely stock cars, or for cars equipped with Sport Cats, Catbypass Pipes, X-Pipe Exhausts, upgraded turbos, and more.
For the 991.2 Base 3.0 Carrera, is there any improvement expected for swapping out the original turbos with the Carrera S turbos, and then installing your software?
I know the GTS has bigger turbos than the S, but not sure if the S turbos are any bigger or any different than the Base Carrera 3.0 turbos.
I am also thinking about this, because there are a few pairs of S turbos available from guys who have upgraded from the S to the GTS engine specs with the X51 PowerKit and it's larger turbos....
1 - 2 of 2 Posts
