1 - 9 of 9 Posts
Boxster/Cayman Specialist
... recently came to my rescue.
You may remember how upset I was last week about my B&M short shifter having broken a bushing and how I couldn't get any response from B&M's "lifetime" warranty without my receipt (from 10 years ago, which I no longer have).
Well, Eric (the main Plug Guy) from Bumperplugs.com immediately contacted me through this board and privately and offered to help me.
He told me that he thought he may have had the parts I needed, but after doing research, he found out that those parts he had wouldn't fit my car, so he contacted B&M and had them overnight me the new parts!
I want to publicly thank Eric for helping me out and for being so customer-oriented.
It ought to teach B&M (and every other manufacturer) a lesson.
A distributor, supporting a customer who hadn't even purchased the part from him.
This is what my bushing looked like, after it broke
Apparently, I had one of the original all-teflon bushings which were more prone to breaking (it ONLY lasted 100,000 miles).
Here are the new parts that B&M sent
This is the new bushing, next to the old bushing
Once I started to assemble the unit, I found that the Porsche teflon slider and the side shifter ball were worn as well.
Notice the play of the sliding ball inside the teflon part
So, since the slider part is a Porsche part and not replaceable I decided to hack it.
By cutting a thin slice of yellow teflon material and sanding it down to the proper thickness
I was then able to slide it into place and take up the slack
then I just assembled everything back together
and put it back in its place
these new bushings even have and adjusting set screw for very precise and no slop shifting
now I can have my old ultra short shifter back
and I really need it for next year to see if I can get a third one of these, next December
Happy Boxstering,
Pedro
Hi Pedro,
glad you have sorted this one out and hats off to 'Eric the bump' :)
btw fyi the genuine 986 short shift kit has bushings with the adjustment screws similar to the ones you now have on your new B&M setup.
Also and notably the 987 Porsche kit comes complete with the housing so no 'chipping' out the old bushes with a chisel, just swap the complete shifter.
Anyhow, Happy Holidays Pedro from England.
It is great to hear that everything finally worked out OK. I'm glad that B&M came through for you, even if it took some gentle persuasion from Eric.
Chuck
I've been waiting on Dice to come out with a solution for the new 09 radios. After reading this I'll order it from Eric.
Cheers to Eric for stepping up when it wasn't his problem :cheers:, glad to see shifter works as good or even better than before....
Enjoying the drive.
See now THAT is customer service and Eric doesn't even work for B&M.
1 - 9 of 9 Posts
