I find launch control abusive and gimmicky, so never use it. It might be the quickest way to 0-60, but it's elaborate, abusive to drivetrain and tires, and other than a freaking dragstrip, it's useless. And if tires spin, might not be quicker. Somebody here suggested a while back that using the parking brake was the most effective launch control. I tried it, and I agree
. You can take off whenever you want, like if on a red light. Plus it'd be obvious to people around you didn't use launch control, which makes it pretty obvious with the engine bouncing against the set rpm limit. Plus it aborts if not released after a second or so. With the parking brake, the car takes off like a perfectly executed start with a manual tranny, around 3K-3.5K rpm (I don't stomp the gas pedal at once though). On my LSD-equipped car, it takes off pretty quickly (not like my ex-GTR, but more than quick enough) even at 4K' of altitude, and the tires don't spin (almost, which makes it the ideal start). I suspect it's probably as quick as using launch control, since that surely spins the tires. I only used it once (and twice on my brother's car
), since my car takes off pretty quickly just getting on the gas, but I'm always in manual/sport modes.
