FWIW, Joyeauto for the win. I popped one into my 981 last March to keep the OEM and it has been great. There may be newer stuff out there, but I'm pretty happy with it so far.
Ernest, I don't have NAV (or CarPlay).. my car has the very basic system, for this reason I wanted to know if by adding the JoyeAuto would allow me to have access to Maps without modifying the OEM look..If you have CarPlay you will not use Oem nav.
Ernest, I was not aware that you could connect your phone (I have an android) to the PCM with an usb cable..!When you have CarPlay it would enable the maps app on your iPhone so you would use that as your navigation not the Oem Nav. It would show up on the screen just like on your iPhone. I don’t need it on my 14 cayman because I can do calls, listen music, Sirius app, podcasts, etc with the usb connection to the Oem PCM. Most if the time the music is low and I listen to the flat 6😊
I just wanted to be able to see Goggle Maps on the OEM car screen, but now Ernest mentioned that he could plug his phone to his Cayman with a usb cable..?I don’t get what you mean about the maps. As stated the new unit will allow you to show Google maps or Waze on the PCM display.
Shawn in VA (USA)
I cannot see the maps on the stock Oem screen with my usb connection. You will need one of the aftermarket CarPlay mods to do that.I just wanted to be able to see Goggle Maps on the OEM car screen, but now Ernest mentioned that he could plug his phone to his Cayman with a usb cable..?
Please forgive me but the electronics knowledge is very limited (technologically challenged?) ...LOL
I usually stick to mechanical components and repairs![]()
Isudur does not have a unit that will work on a cdr-31, thats what I have. Look at zz-2.com , works perfect here.Hi all,
I've been looking at the various options for adding Carplay to my Cayman to replace the CDR-31 base unit.
I've considered the various add-on boxes from JoyeAuto, NMAutomotive and the various similar units on Alibaba and have nearly purchased a JoyeAuto unit several times, but whilst I like the idea of preserving the OEM look, I'm also now drawn to some of the Android head units out there.
I've looked at Xtrons and checked with them, but unfortunately they don't have a unit which will fit the 981 and have no plans to make one. Same goes for Dynavin.
Have also seen other options like this pricey one from Belsee but not convinced it will fit the 981:
Belsee Carplay unit for Cayman
This one caught my eye recently as it also has physical knobs which I like, better screen and supposedly much more modern internals. Of course there's always the chance that this will turn out to be a piece of **** with zero support from the manufacturer, and set fire to my car, but at only about £180 on eBay I figured it might be worth a shot :
Erisin Carplay unit for Porsche Cayman 981
Not being a car audio expert I'm not sure what wiring adapters or other splicing work might be required to fit this unit - here's an image of the rear showing all connections - can anyone tell me how easy difficult fitting might be in terms of wiring?.
Any other options that I've missed for adding Carplay to the 981?
Thanks!
Hi Gilles,Thank you for the link Shawn!
I am curious to know which system they are installing, the price seems very reasonable, but the car would be parked for at list two weeks..
On Rennlist I found about NM Automotive (UK), which sells their system for around $500 USD plus installation.
I also checked out zz-2.com (suggested by Bob) and they sell their system for about $950 USD but they don't sell direct and it seems that you have to use one of their authorized installers which will add their labor as well.
