A question to the masses about sensor design. See picture at bottom.
There are grooves along the side of the aluminium casing that are aligned with three of the sensors (red arrows). The shift rod magnets are on this aluminium side for those three sensors. There's another groove that doesn't seem to align with anything (green arrow). The magnet for shift rod 4 is on the other epoxy fill side, and there isn't a groove here as it's just flat epoxy.
PV and I have been discussing offline what the purpose of them might be, and we can't seem to find a reason they are there. Anyone got any ideas? It will just make the CAD drawings easier if not required. CAD drawings should hopefully be reasonably simple. Nicely rounded edges around the end connecting holes aren't required as there is loads of spare space here. It's just the center connecting hole that needs to be the nice shape as one of the shift rods gets to about 2mm away from it.
I'm also interested in some feedback on the material of construction. The OEM and other aftermarket sensors are made of aluminium. It seems this is going to be the most expensive part of a sensor. We have the thought of 3D printing it from glass or carbon reinforced nylon. This is the stuff lots of parts in the car are made of. Transmission pan, intake manifold, and lots of sensors are examples. My guess is the transmission speed sensor is made of it.
We ask the question why the OEM sensor is in an aluminium casing. We think it might be because it needed to be a potted sensor, and to try and pot effectively into an extruded plastic casing wouldn't have been possible. The epoxy wouldn't be secure enough in this environment. The beauty of 3D printing is that those problems wouldn't occur. It would be easy to 3D print a casing that has loads of loops/jagged edges etc that when potted will hold the epoxy very effectively. You could even 3D print an inside overhang in the casing edge so it was physically impossible for the potting to come out. The temperature capability of these materials is the equivalent of the sensors, as they have better heat resistance than standard nylon.
3D printing of this material doesn't use a particularly expensive/bespoke machine compared to aluminium. There would the need to reinforce the screw holes. Maybe a stainless tube. It doesn't need to be particularly strong, as the screw is M5 and will take 8 Nm. We are thinking a sleeve could be just pressed into it like they do for the transmission pan or any other sensor made of it.
Can anyone see a good reason for not pursuing this? Strength, resistance to using a plastic sensor, anything else? Ideas on which, carbon or glass would be the most appropriate? Carbon = stiffer and stronger. Glass = better impact resistance.
Some additional info for reference:
Both of the aftermarket sensors have the grooves. The XemodeX website has pictures of their sensor internals, and the sensors themselves are right up one end well away from the grooves. I don't know if they just put them there because the OEM did.
Magnet distance from sensor side is about 1.5mm on the aluminium side, and about 2.5mm on the epoxy side. The grooves are 0.25mm deep.
When I removed the distance sensor the other day from the project car, there was a load of ferrous sludge on the magnets. This is normal, but there was so much it was touching the sensor. The sludge looked like it was being pushed to the sides of the magnet as the gap reduced to nothing and more sludge gathered over time. This car only has about 60,000 km. I would imagine that if you opened up a transmission that had a lot of miles you would have a really good accumulation of sludge on each magnet, with most of it being pushed to the side and the gap between magnet and sensor remaining filled.
Of interest the transmission I pulled apart had only about 15,000 km, and the level of magnet sludge was minimal compared to the car. The 15k transmission is from a Cayman GTS with a bunch of track time, the 62k transmission is a base Boxster with just street usage. I thought there might be initial wearing in of the gears that would accumulate quickly and then settle down to nothing as time progressed. This seems to indicate otherwise, with progressive wear seeming to occur. Very small sample size to come to any sort of firm conclusion though.
