Thanks for the link. Much appreciated.Excellent progress... great info! I'm glad you did the oven test... and found that it wasn't going to hold up as well as the specs say. Better to see that before it's in a car!
FYI, not that this is necessarily a solution for you, but when we wanted to "quench" some of the stray magnetic fields (back in my semiconductor engineering days) we would put a u-shaped iron on the magnet, so that the field had a "path" to follow. Basically, if you put a metal cap on the disc-shaped magnet in your picture, it might help direct the stray field and keep it from going too wide.
I think the angled sensor is the best idea for now, or moving them a little further away if you can. Or maybe specifying a "weaker" hall sensor component.
In any case, you're all on the right track for sure! Just wanted to give a few other ideas/options.
EDIT: Here's a picture of what using metal to "short circuit" the field looks like:
The article may be related, but I thought the picture was perfect to show what I was trying to put into words.
PV has got some special magnetic field blocking material on order to see what can be done. Certainly the link provides some guidance rather than us just guessing.
That being said, it seems there is a lot of flexibility within the TCU when doing the cal. It seems to take readings of the magnet distance when a gear selected, but also with the possible pre-selections and keeps all these for reference as well. We are thinking that if we can just tone down the interference to a reasonable level it should be fine. It still seemed to be OK when doing the testing even though it was jumping a huge amount when other pre-selections were happening, so making this interference less by tilting back is going to reduce an issue that really doesn't seem to be an issue at the moment. We just want to make it better.
Regarding the melted wiring on the sensor after the test, I've spoken to PV about this and he said the wiring on this sensor was just some cheap stuff from the local electronics shop. He's sourced wiring good to 200 C for the real thing.
