Status
Not open for further replies.
1 - 20 of 68 Posts
This will be the best thing you have ever put in your car! Solid shift, shorter throw, and perfect fit. Better then OEM, better then B&M, better then any other out there or your money back!
I am doing the Agency Power Short Shifter and Billet Shift Linkage for $250 plus shipping for Planet 9 members. Minimum is 10 people. If you want it right away, it is $295 shipped.
View product information here:
Shifter - Agency Power Billet Short Shifter Porsche Boxster, 996, 997
Shift Linkage - Agency Power Shifter Linkage Porsche 996 997
Installation Tips - Agency Power» Blog Archive » Porsche Short Shifter Installation
Sounds good. I'm in at $250 + shipping.
BW
OEM uses a plastic housing and still has a longer throw. It also uses the factory linkage which is plastic with a rubber insert and prone to breaking. Comparative to the B&M, the design is similar, but the shifter uses a nicer journal bearing for smoother shifts and the shift linkage is a key part to precise shifts.
Is the installation 100% reversible to stock? or is it like the B&M that I need to break a plastic piece in order to install it?
1 - 20 of 68 Posts
Status
