I found my front (Boxster S) caliper seals have become mostly melted. Can you confirm the boot and seal size is 38mm? I ordered a set from RB Performance Brakes and they sent me:
  • Dust Boots - 8 ea. (38mm)
  • Oil Seal - 8 ea. (38mm)
Also, I paid for the high temp versions which are blue. Have you heard of these? They were another $50.
Thanks in advance
2014 Boxster S, Racing Yellow
Correct. The OEM-style boots just seem to turn to dust after a year or so of track use. I've been just buying the Centric ones from FCPeuro and including them in my regular maintenance.
I found using a dental pick helps to remove the old ones. For installing the new ones I found this trick when I was rebuilding calipers on my e36:
1 - push the pistons out from the caliper about 1/2 inch, either with a little pressure using a Motive bleeder with the bleed values closed, or by using light pressure on the brake pedal. I recommend using a block of wood to keep the pistons from fully exiting, possibly with extreme force.
2 - optionally lubricate the boots with some brake assembly lube, especially on the mating rings
3 - flip the boots inside out
4 - slide and fit the boot to the grooves in the piston side first
5 - push down on the outer ring of the boot to flip it over and seat in the caliper side. The boots should flip back over nicely into an accordion position.
Thanks for the details. The block of wood is a good tip. I used some compressed air with a block of wood to get the pistons out. I had one side come out fine but not the other. I used a C clamp and one of my shims to hold them in place to get the others out. What about the O rings on the inside? If they are not critical I would rather just replace the boot but the videos I have seen replace the ring as well.
Would you happen to know the torque specification for the hardlines to the caliper?
If you pop out the whole piston, not a bad idea to go ahead and replace those o-rings - you've pretty much completed a caliper rebuild at that point.
Brake line-to-caliper torque is 16nm (12 ft-lbs)
