Hi,
This post is regarding my 2008 Boxster S Limited Edition. About three years ago, I had one of my OEM TPMS sensors go bad. At that time, I needed new tires anyway so I went ahead and had a new set of TPMS sensors that I got from Titan installed on my 19 inch lobster claw OEM wheels. When I first drove off, I got the TPMS "Wheel change?" message and reset the TPMS through the steering wheel stalk as per the owners manual. A few days later, the "Wheel change?" message came up again. I didn't think anything of it, and reset it. Since then, sometimes once a week, sometimes as frequently as every other day I will get this message. Resetting the TPMS through the steering wheel stalk buys me some more time and gives me the tire pressure numbers on the dash. Sometimes, right before I get the message I will notice that on the left side the pressures from front and rear are switched around. Has anyone had such symptoms? I did a search and did not find anyone with a similar situation. I am up for new tires now, and will replace all four sensors at the same time. A friend with a 2008 Boxster S has ITM TPMS sensors from Titan TPMS and apparently has had no problems with them. I am thinking of going this route.
Any input is appreciated!
Thanks,
Franc
Thanks,
Franc
