1 - 14 of 14 Posts
Senior Porsche Financier
For street and moderate track use (on street tires ...) -- and w/ a dozen track days w/ stock pads I don't have any cracking in my original rotors. I will be upgrading to PFC 97s for the track and keeping OE pads for the street.
anyone tried:
1) Disk Brakes Australia (DBA) 4000 for the CS ? -- available at tirerack ...
2) Balo, Sebro, or Zimmerman - available @ pelicanparts - these brands are listed on the product page "(brand) is an OEM supplier to Porsche."
does that mean they supplied Porsche w/ some parts @ some time, or, is this particular rotor is supplied to porsche?
The Balo is about $80 ... I can throw away a lot of these if they crack early, before touching the price of Performance Friction 2-piecers and the like ...
I understand the adage about "getting what I pay for" ... but if someone has successfully used these rotors, I may get a little more for the money, than porsche OEM ...
Built for speed AND comfort.
I ordered a pair of Balo fronts from Pelican for my 987 Boxster S, so I will post here as soon as I have some feedback (after a couple track days). My original rotors are good for one more track day, I think, and then it'll be time to change to the Balos.
What I've read over on the Bimmer and Mercedes forums backs that up. At $80 apiece, unless they totally **** out it's hard to argue that the big-buck rotors are worth it for street / occasional-track-day warriors like me.
(Disclaimer: I know rotors are a lightning rod issue on forums.)
thanks for the reply - I decided to go w/ DBA series 4000XS [DBA 42394XS] - @ $175 They're not cheap, but seem to have some great engineering behind them. These are sparsely drilled & sparsely slotted - I still get better cooling than slotted-only, w/ less likelihood of cracking.
I'd have gone w/ something more basic except I'm going to use these in my CS w/ track pads so I wanted more than the least expensive option.
I just bedded my PFC-97 pads today w/ the new rotors - braking evenly and medium-hard from 80 to 40, and so far I'm pleased. I'll be taking it to the track next weekend and will report back.
If Belo is truly OEM supplier to Porsche then could it be that these same rotors are on many of our cars. My adage is - "you are too poor to buy cheap stuff." But if I can get a decent $80 rotor... I bought some nice Brembo rotors for $40 few years back...
Let us know how the DBAs work.
for what its worth, i replaced my stock rotors on my Evo8 that i used to own a while back with DBA rotors (cant remember which model). they were a solid choice for me back then. hope yours are too!
Nice looking rotors, although that's about the same price as Porsche factory rotors. Do the DBAs offer anything (other than a different hole/slot pattern) over the OEMs that you're aware of? Still, good to have choices! :)
their 'kangaroo paw' vent design. I buy the idea that radial vents are more prone to warping ... that, and the 3 stripes of thermo-paint on the edge. I'm not sure how I'm going to be able to see them but it's a very nice touch.
I probably would have bought the balos except that pelican was out of stock for my CS when I wanted to place the order. Seeing them back in stock I'm kicking myself a bit ...
I used DBA almost exclusively, 5000 series, in my previous cars, excellent quality IMO. I replaced my rears with Zimmermans, although the value is there, they are now toast already after 5 track days in less than 8 months :( I may go with OEM rotors after the next event for the rears to see if there is really a difference between them.
Plainsman, I'm curious what you have found with the DBA 4000 rotors. I assume you've given them a good track thrashing by now?
There don't seem to be a lot of options out there for rotors.
  • OEM / OEM quality are available, reasonably cheap but all seem to be drilled.
  • Girodisc rotors look really nice, with price to match. :eek:
  • I haven't come across much in the way of a middle ground option.
Also wondering about which ones you bought. It seems as if they make either slotted only or drilled and slotted for the fronts: based on my experience with cracking at the holes on EOM drilled rotors I would probably favor slotted only.
Look forward to any feedback you have.
Cheers --
I'm also curious to hear about the DBA's.
wgn - a middle ground option might be two piece rotors from performance friction. Have not seen them in person, but from photos they appear to be dimpled rather than drilled.
Discussion Starter · #11 ·
Cheers --
The only thing I thrashed @ the track was a rod bearing ... 40 minutes on the track and my weekend was done. I got the 4000XS (X-something?) -- lightly drilled + slotted, kanga-roooo pattern separators between the disc halves.
I like them - w/ these rotors and PFC-97 -compound pads I was able to stop very well.
It seems silly now that I'm spending $20K on my engine, but I balked at the extra cost of the performance friction 2-piece rotors -- they were my first choice.
Might as well step up to the best slotted rotor - a huge increase in diameter from 317mm to 340mm - via the GiroDiscs. Just 10mm shy of the GT3 rotors.
But then again you knew I'd chime in anyways :cheers:
You are one sick MF'er watching all these posts and picking up on the ones that are brake related. I wish I had such energy.......keep up the good work. :hilarious:
1 - 14 of 14 Posts
