1 - 8 of 8 Posts
Thanks in advance for any help! I heard if you have the wheel, the dealer just activates it. I also heard that the MF wheel is only compatible with the PCM. I only want volume and track changing ability...no phone necessary.
Thanks!
The MF wheel is ONLY compatable with the PCM not the CDR units. The CDR units do not have the software to communucate with the steering wheel electronics.
Really? My 06 Cayenne had a multi-function wheel with a CDR24 and Bose, but no PCM. Perhaps the systems for the Cayman are very different from the other Porsches.
I've seen that the PAC SWIJACK is only certified to work with the Cayenne's, however I saw something else about adding in resistors to the steering wheel's buttons/switches... anyone try this? Or am I going to have to be the guinea pig.
PAC SWI JACK info: http://www.pac-audio.com/swixprogramming/instructions/swix%20locating%20wire.pdf
and SWI-CAN http://www.pac-audio.com/productDetails.aspx?ProductId=208&CategoryID=29
http://www.pac-audio.com/swixprogra...mmSearch=Porsche&Submit2=Search+Vehicles&ID=8
similar trick: http://p-car.com/diy/steeringradio/ <-- good info
Resistor Kit: Some vehicles have a separate wire for each of the steering wheel buttons. Use the resistor kit for steering wheel push buttons that do not already have a resistor network connected to them. The resistor kit includes the following resistors:
  • 47 Ohms (yellow, purple, black, and gold bands)
  • 150 Ohms (brown, green, brown, and gold bands)
  • 560 Ohms (green, blue, brown, and gold bands)
  • 1000 Ohms (brown, black, red, and gold bands)
  • 1500 Ohms (brown, green, red, and gold bands)
Does anyone know how the Cayman's MF steering wheel's controls are sent: (5 options )
1. Negative Control wire.
2. Positive Control wire.
3. 5-volt data Control wire.
4. 12-volt data Control wire.
5. individual pairs per switch
I bought a Carbon Fiber MF steering wheel to replace my stock steering wheel with no buttons.
I swapped the side pieces from my stock wheel over to the new CF steering wheel.
So I have the multifunction buttons and the little piece they're connected to that then in turn connects to the wire harness. I was planning on doing some testing to see if there was anyway of by passing the computer system and using the buttons some other way, but I think I just gave up on it.
and SWI-CAN Pac-Audio.com Product Details | iPod Integration for your car and More by Pac-Audio - Connecting you to the future
Pac-audio.com Steering Wheel Interface | iPod Integration for your car and More by Pac-Audio - Connecting you to the future
The function buttons are input to the radio via the CAN bus connections C1 and C2. I suspect that means they would fall under catagory 3 or 4 above. I think the appropriate design is interface C1 & C2 to the SWI-CAN and have the SWI-CAN drive the SWI-Jack.
1 - 8 of 8 Posts
