I would like to use 17" base rims with snows on my 987.1 S. Is it correct that I need 7mm spacers for the fitment over the S brakes?
Thanks!
I don't see a correlation between wheel diameter and wheel offset which spacers would give you. The wheel should clear the brakes without a spacer.
PCA Nat'l DE Instructor
I've retrofitted my 2007 C with CS brakes, and you will need 5-mm spacers (and longer wheel bolts) in front for the 17" wheels to clear the wider CS brake calipers. I'd recommend using 5-mm spacers all around.
