1 - 20 of 25 Posts
This question may have already been addressed but I couldn't find it. I have a spare Battery Tender Plus battery maintainer. Is this okay to plug into the 12v outlet in the arm rest? I'm sure it would be fine to wire a connection directly to the battery but I would like the convenience of just plugging it in. Anyone else using one of these specific chargers? Thank you.
That's the approach I use for my 2009 Cayman as well. Battery Tender has an adapter to use for the cigarette lighter outlet. Much easier than trying to figure out how to close the bonnet with the alligator clips connected to the battery.
Should work just fine. (IIRC, we had a group buy on those chargers a couple of years ago)
I started wondering if the Battery Tender Plus brand would work because I have a BMW motorcyle with a Canbus electronic system and BMW says it can't be used with the 12v outlet---only if wired directly to the battery.
I use the battery tender JR and plug it into the socket in the center cigarette lighter plug. Have had no problems, battery has remained fully charged.
:burnout:
Might be that the Lighter socket on the BMW bike is switched. Just a thought.
I'm using a CTek maintainer via the cigarette lighter socket in the arm rest. Has worked fine for several weeks to keep the battery up, and no problems that I'm aware of.
I just bought a CTEK 7002 w/ cigarette lighter socket adapter and am using it for the first time today - plugged into the cigarette lighter in the ash tray, not the power socket in the bin behind it, it appears to be working perfectly, progressively charging the battery for the past couple hours. Very nice device. Dave
I'm with Schwabe on this one. I know you must plug your air compressor into the cigarette lighter, but I do the same thing with my Ctek because it can take more current without blowing.
That's the way I use mine. The socket is on all the time.
It looks like my local dealer keeps his charged the same way. The cars on the floor are plugged in the same way.
Discussion Starter · #13 ·
It looks like my local dealer keeps his charged the same way. The cars on the floor are pugged in the same way.
So--you are using the Battery Tender Plus brand?
I'm using a Deltran 2 station battery Tender, I think it's a plus.
The Delatran can plug in different connectors - clips, plug or directly bolted on to the battery.
Have no idea what the dealer uses.
Discussion Starter · #15 ·
Great--thank you. Should be the same technology I have with the Plus model.
Discussion Starter · #19 ·
I'd still love to know why the footwell outlet is not the same as the cigarette lighter outlet???
The cigarette outlet has a heavier fuse to run the tire inflation pump. The foowell outlet is for lighter loads, e.g. radar detector. Or so I have read.
1 - 20 of 25 Posts
