501 - 518 of 518 Posts
Nice snails.
see i hybernate from this forum for about year come back today to be nosey and see this kind of ****ery going on :hilarious:
well, well well twins!!!
Diver, I have been meaning to ask around but are you running the factory valves? if not what are you running for intake and exhaust valves, any coatings?
Cayman The Destroyer!
Discussion Starter · #505 · (Edited)
To much loco weed I guess! LOL Factory valves. No super high tech coatings. I discussed coatings with Vison and they didn't recommend doing it so I followed their advice.
Discussion Starter · #506 ·
Headers coming along. Fitting all of the stuff in the available space is a challenge.
Discussion Starter · #509 ·
Still need the waste gates but it's getting closer to making some noise.
Diver, is it safe to assume that insulating the exhaust down pipes to the turbos are in the plans? Otherwise I'd be concerned about the close proximity to aluminum pieces and suspension bushings.
Discussion Starter · #514 ·
Yes indeed the pipes will be insulated. No mufflers but we will be doing an add on from the V bands back with mufflers to enable running at noise restricted tracks. Here is a final pic of the evolution from a stock TPC system to a custom twin turbo with air to air intercooler.
That beast is going to howl as it idles with no muffler. So cool. Very nice looking setup. Hopefully repeatable for others with less means to innovate looking for off-the-shelf solutions to the cayman/boxster hp shortfall. Thanks for sharing the journey
Discussion Starter · #518 ·
The standard TPC turbo kit is a great solution for street or DE use. There where many lessons learned from the evolution of this engine a some of them would reduce cost on another build but there are no jigs to build the plumbing so I'm afraid it would still be quite expensive to duplicate this setup
