· Registered
Hi all,
I was at a HOD event at Thunderhill, driving pretty aggressively (redline occasionally) when on a relatively wide turn (Turn 2 for those who know) I lost power. My dashboard lit up saying check engine, bring service, and my Cayman was doing a Spy Hunter impression with white smoke billowing out of the tailpipes.
I immediately left off the gas and drove through the remainder of the course to get back to the pits.
By the time I got back to the pits, the dashboard stopped doing an impression of a christmas tree and the smoke died down a bit. I turned off the engine and inspected to see if I blew anything. But I found nothing leaking and only evidence of dry black soot in the tail pipes.
After letting it cool down a bit, I restarted the engine. Everything on the dashboard was good and only a light white smoke from the pipes.
I drove it back down back to the SF Bay Area and had no issues - power was still good, no obvious smoke, temperature was good. Starting it this morning, only minor white smoke for a couple of minutes.
Now, knowing the previous issues from oil leakage (need to get my separator installed) with people who track their car. Should I be worried?
I'm scheduled to have the dealership take a look tomorrow, but would love to get people's feedback - help? suggestions for the dealer to look at tomorrow? etc?
Thanks in advance,
Eugene
· Registered
Hello Eykim,
You should not really be that worried. This has happened to most of us that have tracked our caymans.
I just fixed mine this last weekend with an X51 oil pan from Suncoast and a Porsche Motorsports VOS.
You can rad the many articles about the oil ingestion issue by using the search....
· Administrator
Welcome to the club of people who have ingested oil, there are several suggested fixes the most common of which is to replace the air/oil separator with the motorsport VOS version which seems to stop the problem for most people. Adding other items like X51 windage trays, etc. is also something that can help.
· Registered
Thanks!
The previous articles that I read didn't have all the gloom and doom of my little adventure.... I seriously thought I blew something and I would be hitchhiking back home.
Should I be worried about any prolonged effects?
· Administrator
Thanks!
Not if your car is running fine now, happening once usually doesn't kill an engine, but repeatedly happening and yes sooner or later your engine will blow.
· Registered
The dealership found that one of my cylinders (#6) misfired. They also found that someone (they as they did the last service) overfilled the oil by a quart which probably exacerbated the problem...
As a result, they replaced the spark plug and ignition coil.
So far so good - phew...
