BMW Winter Alloy Wheels/ Dunlop Tires- X3 2003-2010 (E83) (also should fit X5 1999-2013, X6 2008-2014) - $900 - No Longer Available
BMW 17 inch Alloy Wheels with manufacturer recommended Dunlop SP Winter Sport Tires (Size 235/55 R 17. 99H speed rating) -- they provide a HUGE IMPROVEMENT in winter driving performance and safety over all season tires. If you haven't tried winter tires in a long time you will be amazed by traction but even more so by shortened braking distance in snowy conditions.
I ran for 4 winters (2014-2017) on my 2009 X3, total winter miles less than 20K. I had separate summer wheels and tires so these rims have been only had these tires mounted-- Lots of tread life left and wheels are in near perfect condition with no significant scratches. I also made sure to avoid stressing the winter tread by mounting too early in season or removing too late in spring-- would only get these mounted once cold weather was settled in, then get them switched out before average temp was above 40 degrees in the spring. I got a new car so selling these. Purchased through BMW Minnetonka.
The package was almost $3500 new. Wheels are in excellent condition and tires have lots of life: Asking $900
The wheels will DEFINITELY fit the E83 series BMW X3 (2003-2010) as that is what they were mounted on. That's the only fitment I can be absolutely certain of. However, the link below suggests that they should also fit the E53 (1999-2006 X5), E70 (2006-2013 X5) and E71 (2008-2014 X6). If you are considering buying for any of those vehicles PLEASE be sure to look at the link below and confirm with either your dealer or a tire/wheel shop to be sure
Here is a link with the wheel info: (see pics showing rim ID 8Jx17 ET46 ).
http://www.alloywheelsdirect.net/bmw_alloy_wheels/x3_e83_alloys/17_bmw_112_wheel_1384
Here is a link to BMW fitment guide for wheels:
http://www.alloywheelsdirect.net/information/fitting_chart/bmw
Here is a link showing the rim fitment which suggests rims will fit "BMW X Series (E53,E70,E71,E83): Again-- if you are considering buying for anything other than an E83 series X3 please confirm that they will fit your vehicle.
https://parts.bmwofsouthatlanta.com/products/BMW-X-Series-E53-E70-E71-E83/2009/Coupe/Light-alloy-rim-8JX17-----ET46/1307272/36113401200.html
Here is a link to the updated version of the Dunlop tire:
http://www.dunloptires.com/en-US/tires/sp-winter-sport3d-tires
List Date: 11/8/2017
For more info, click here to view the original listing: BMW Winter Alloy Wheels/ Dunlop Tires- X3 2003-2010 (E83) (also should fit X5 1999-2013, X6 2008-2014) - $900
This item is no longer available.
