by: jderiansf
Description: The goal of this article is to show the step by step process to put a 987 Boxster into “maintenance mode”. You’ll need to access the engine compartment to change the air filter, or install a custom intake etc. This is only a guide, an I take no responsibility for errors, or problems with your car. But I will gladly make changes to the description, as necessary.Step one: Park the car on a flat surface, leave the car in gear, and set the parking brake.Step two: Open the convertible top approximately 24 inches; just enough to raise the rear cover to its highest point. Now remove the key from the ignition, to prevent accidental operation of the top.Step three: Disconnect two tension rope the ball–pivots located on either side of the convertible top. Just pry gently, and they should pop right off. You may need to remove the convertible top hinge covers (if not now then later to access the Bose speaker plug).
