1 - 2 of 2 Posts
CampioniShop is bringing exclusive and high quality lines to Planet-9 on a daily basis. We highly believe Brembo fits in those criterias and would like to present Brembo's offering for the Cayman !
Gran Turismo BBK 6 pot front and 4 pot rear
Cayman Specs:
Front:
6 pistons monoblock aluminum cast calipers
355x32 (18" wheels) 2-piece OR 380x32 (19" wheels)
The 380mm will clear a few select wheels.
Drilled OR Slotted
MSRP 380mm: $4250
MSRP 355mm: $3695
Rear
4 pistons monoblock aluminum cast calipers
345x28 2-piece
Drilled OR slotted
MSRP: $3295
Not suitable for PCCB !
OE standard equipment on 2010 Cayman S:
4-piston monobloc aluminum fixed caliper brakes front and rear,
discs internally vented and cross-drilled
disc diameter (front/rear): 318 mm/299 mm, thicker at rear
  • The Brembo Gran Turismo Drilled Brake System is a complete braking kit that's custom-designed for demanding performance in your vehicle
  • Proven and tested against Brembo's world-leading standards to ensure success in both high-performance and street driving
  • Brembo Gran Turismo Brakes' floating disc design also contributes to braking power and enhances pedal feel
  • A selection of four Brembo caliper colors is available: Red, Black, Yellow and Silver
  • Brembo Brakes are fully compatible with the stock master cylinder and ABS components
  • Brembo Gran Turismo Brake Systems use eight-piston cast aluminum calipers that provide maximum braking force without the flex of sliding calipers Engineered with a floating disc mounting system and a billet aluminum hat to reduce "unsprung weight" for lower temperatures, better handling and diminished heat-related stress
  • Sold in front and rear pairs when available
  • Backed by a 2-year warranty
1 - 2 of 2 Posts
