1 - 20 of 33 Posts
CampioniShop is proud to present exclusively to the Planet-9 community the Meisterschaft exhaust systems.
In the past, we have provided many stainless steel exhaust systems to fellow members. To my knowledge, this is the only titanium exhaust offering on the market today for the 987 Cayman/Boxster Gen 1.
P.S.: SS Headers with racing 100 cell cats. are available!
About Meisterschaft:
1. Weight - Both Meisterschaft Touring and GT models are significantly lighter than the OEM unit to reduce the carrying weight. With the Meisterschaft Ti Titanium units, you will be able to shed up to even 75%-80% of the weight from the OEM unit.
2. Performance - All of our Meisterschaft systems are designed and tuned to provide maximum performance gain without sacrificing the exotic exhaust note. The performance gain will be even greater when the Cat-back mid pipe sections that are used in conjunction with the Meisterschaft rear muffler units.
3. Build Quality – Plasma laser Welding technique and supreme quality internal construction are handled with extreme care and also given more attention to details compared to other brands. Furthermore, higher grade glass wool pack has been utilized for Meisterschaft units which can withstand extreme temperatures. Application Fitments and Fine Finish of each unit are all carefully pre-tested, quality controlled by a personnel everytime before unit gets shipped: we examined Meisterschaft to the perfection.
4. Material - Only the highest grade T304/T316 SUS from POSCO steel is used for Meisterschaft Stainless Steel (SUS) units and premium titanium alloy from Shin Nippon Steel are used for Meisterschaft Titanium (Ti) units.
Titanium exhaust - 2x83mm round tips
MSRP: 3998.00
Stainless steel exhaust - 2x83mm round tips
MSRP: 2798.00
Any video clip?
Discussion Starter · #10 ·
Meisterchaft only told us it provided a 15whp gain, no specific dyno graph. Supposedly they dyno'ed their system with a heavily modified car hence why they didn't make the dynos public.
Drone? While I understand it is hard to be precise in whether there is no drone or some variouation of drone, the design on face value would seem to be one prone to it. I know better than to just assume, however......... CORSA makes exhausts that with the smallish muffler would seem to be drone prone but are, in fact not, due to the use of resonant sound canceling. So, I am interested in the answer to the question. Thanks much.
Discussion Starter · #13 ·
There will be drone, no question about it. The one question that you would need to answer is if you are able to live with it on a daily basis if this is your daily driven car?
The drone will come in between 2500 to 3000 RPM. It will be similar to other "race" systems such as the Supersprint, REMUS, Borla, etc.
Noise cancelling chamber from Corsa and other manufaturers like AA and ARK are great, however they add unnecessary weight to the exhaust system which in this case, with a full Titanium construction, goes against the original purpose of this system.
Discussion Starter · #16 ·
It will be very similar to the "race" branded exhaust systems on the forum such as the Borla and REMUS. Expect slightly most rasp due to the titanium sidewalls.
1 - 20 of 33 Posts
