1 - 3 of 3 Posts
I'm curious if the SmartTop system offers something I won't get from a third party alarm system like Compustar. I know Compustar has modules you can add which will allow you to control your windows, heated seats, defrost or just about anything you can imagine. I assume you can also hook it up to the car's top so I'm curious if anyone here has done that with an aftermarket alarm / starter system. I also know there is a module you can get to allow access from the mobile application so you would be able to control all of these accessory items through your phone.
A second question I had about this is that Compustar specifically states in their installation manual that you should not install it on any convertible. Does anyone know why? The manual doesn't specify a reason, they just repeatedly state it should not be done.
I'm trying to decide between SmartTop and Compustar so any information would be helpful.
What year Boxster? As far as controlling the top - that might work fine after someone gets into the car and releases the center-lock on the top, or when putting the top up, fastens it.
1 - 3 of 3 Posts
