1 - 12 of 12 Posts
Late last month I completed an install of the Cargraphic lowering springs for my 2007 Cayman S. On a recent trip to Los Angeles, I picked up the spring set from the North America distributor of Cargraphic products. (I though they were a sponsor at one time but I did not see them listed any longer) I also want to thank “Adax” for the great lowering spring install article & all of the contributors that posted comments & suggestion as well; especially “wpmjr” on the helpful tip on the socket for PASM equipped cars.
The install went extremely smooth, I had my friend machine a slot in the 21mm deep socket to disassemble & reassemble the front strut & he even had a spanner pin wrench for the top washer of the strut. The only real issue I had was that the rear strut had a 19mm nut & I did not have a slotted deep socket. The disassembly of the rear strut was not a problem & I was able to apply proper torque with a “Crows Foot” which worked out perfectly. As was recommended in the comment section of the article, I too disconnected the lower control arm from the in-board pivot points to remove the strut & it was an easy procedure.
I am extremely satisfied with the Cargraphic lowering springs & I my first & foremost objective was to decrease the gap between the fender & tire. Furthermore, the ride is extremely compliant & I have no negative feed back on ride quality. I have attached a few pictures of the install & one after picture. I have more pictures that I will post later.
Thanks....JKman
Beautiful color on your Cayman, lowered on those turbo wheels it looks really good! The wheels are now crying out for spacers.
BW
Nice job. From the pics, it doesn't look as low as some of the other manufacturers which is a good thing. Do you know how much of a drop it is?
-Moto
I thought there was an issue lowering a PASM car?
Another thing, Do you get any wheel hoping / axle tramping on a fast launch? I seem to have a major problem with this on the new CS. Car is 2010 stock with PASM and LSD.
Discussion Starter · #9 ·
BW
I agree, I do need wider spacers. I currently have the Porsche 5mm spacers & I want to get a set of 15mm for the rears. I think the front is ok but the rears could use a wider track.
The mod bug just won't stop.... As many of you have, I too have the SRP & 4.1 flash, exhaust, lowering springs, V-flow intake, ultimate pedals, de-snork, painted intake, etc, etc. I still want to get spacers, HIP CEC, braided hose & AN fittings for some of the plumbing, maybe a Sprint Booster, Mod for Cars... It just won't stop!!
Oh well, I just have to keep feeding my addiction, it could be worse.
Discussion Starter · #10 ·
-Moto
Per the "Post Your Ride Height" tread, my original measurements were 14 1/4" in the front & the rears were 15". After the Cargraphic spring install the measurements are now 13 3/4" in the front & 13 7/8" in the rear. The car now has a flat stance with no front rake. The difference from stock is 1/2" in the front & 1 1/8" in the rear. This is a lot differnet from others that have these springs.
Discussion Starter · #12 ·
Yes, I too have heard about issues with lowering springs on PASM equipped cars but since Cargraphic specifies that their springs are compatible with PASM & I am not going to track the car, I will just take my chances. Also, I have not noticed any of the symptons you have described on a fast/hard launch. Very planted & stable.
1 - 12 of 12 Posts
