I picked up a Carlink AI box: Amazon.com
I have it connected via USB into the socket under the center console arm rest of my '17 GTS (with PCM4, iirc).
Essentially, it's a small Android unit that fakes the PCM into thinking it has a wired Carplay connection. PCM touchscreen, speakers, mic... all seem to pass through to it.
It also has the ability to act as a bluetooth "go between" to allow wireless Apple Carplay and Android Auto. I don't use any Apple junk so I can't testify to that. But since this is, basically, a full Android device it kind of doesn't need to have your phone connected to it at all. Because all your regular PCM pairing for the phone still works (phone calls, etc). You can put a SIM directly into the Carlink box, or you can have it join an existing wifi network. I have a SIM in my PCM that hosts a hotspot, so I just joined this box to that WiFi network. The SIM size in the PCM is larger than the AI box uses, otherwise I'd have tried it that way.
Initial testing was impressive. I logged into my Google account on it and loaded up several Android apps. Waze, Pandora, etc. All loaded and appear to work just fine. I used Waze for directions, with a Pandora stream playing and it handled switching the audio between music and directions without a hitch. Note, this was using the apps ON THIS DEVICE. Not through my regular phone. It'll do that too, but I didn't test it as this is a pretty good use of the PCM's touchscreen. I also tried having Waze doing directions while listening to SiriusXM on the PCM itself (not streamed). Again, it handled switching between the PCM music and the Waze directions pretty well. Though I do feel like the audio from the Carlink box could have been a little louder, but I haven't dug into the settings to see how much I can change.
I'll report more as I get a chance to put it through its paces.
