Cayman S, GT3 LCA's, PSS9 just rebuilt, corner weighted and aligned.
Hey Guys. Not sure if this is the right section but looking for input to the Troubleshooting of a shimmy or vibration that occurs when taking sharp right at decent speeds >30km/h (loads up on left). Intermittently, a judder is felt on the left Front is felt through the steering wheel. I haven't been able to record this.
Separate to this, I found that I get this judder shake when turning the steering side to side on the spot.
eg.
https://www.youtube.com/watch?v=NIovd9o8bJU
While separate scenarios, the common factor is that vibration only occurs on the left front so I'm starting to think these 2 symptoms are related. It is triggered by the grip in the tire. I believe I can reproduce the judder when turning right on loose road surface like gravel (hard to find but like a round-about).
So far, 2 shops have said there is no play. I did have the inner tie rods replaced a 2yrs ago and drop links recently replaced.
Notes:
- It's only happening on the left side too.
- No noise or issues going straight
- I do get slight shimmies when turning a 90 degree corner at speed 30-60km/h. Slip angle of front tire seems to be a required parameter.
- Don't feel any issue on long sweeping corners. If I'm being picky, sometimes I feel a strange wobble on the left tire, like a tremor.
It could be the tire but then I think the suspension should be able to absorb any vibration instead of transferring it through the steering quite dramatically. I've read about ackerman effect but believe this shouldn't happen to this level.
What else can I check. Wanted to your experiences before I go for around of diagnostics or determine if I will go with a proactive remediation plan such as refresh components anyway. Also Happy to hear any recommendations on components I should consider refreshing at 93k kms!
eg.
Notes:
