Hi all,
Ive been trying to access the relay panel that's by the drivers footwell on my 2007 Cayman s. I've taken off the carpet by the fuse box cover but cant seem to locate the relay panel? Does anyone have a photo of the exact location or a description of how to access it?
Thanks!
There's another relay panel that is above your feet (when driving). Do a search, I know I've seen it on this board. The relays are facing up, so you can't see them without unfastening the panel and turning it over.
Remove the fuse box cover then the screws of the panel pull it out with the carpet then look up yull see a black square cover. Pull it off then you will see a bunch of wires. Push up then turn the relay holder accordingly back down. What i want to know is which relay triggers the a/c clutch coil?
