I heard that the Cayman S sway bars are thicker (stiffer) both fore and aft. Does anyone know about this? If so, can the stiffer S bars be installed on a base Cayman? The ride on my Cayman is about as stiff as I want for street use, but the 18" Cayman S tires with the stock sway bars give me a bit more roll than I am happy with. Is this crazy or would an upgrade (if possible) help the handling? I often have a passenger (wifey) and even though the roll in my Cayman is much better than my ex BMW Z4, I am always looking for improvement without harming the overall handling characteristics. I was hoping that someone with a Cayman S who upgraded to some racing sway bars might have keep the old bars around and would be interested in selling them.
I believe the swaybars are the same between the Cayman and Cayman S. If you want to increase roll stiffness the usual approach is the TPC set-up or GT3 front and Tarett or H & R rear bar. The other option is to lower the car with H & R or Eibach springs, both are stiffer then stock. All of these options will compromise "ride".
Re: Cayman sway bar upgrade...
I found out the all the Caymans have 24 mm front and 22 mm rear sway bars. There is no difference in the base and S model sway bar setups. The H&Rs seem to be the best bet as they are a mild step up from stock and will probably give me the best compromise ride/handling. I will proceed based on that assumption. The rear H&Rs have two holes for stiffness adjustment. I'll probably start with the least stiff setting for street use and move them to the full stiffness for DE use, etc. I suspect using both front and rear H&Rs will leave the under/over steer about the same? Any comments?
Do a lot of research on sway bars before you buy. Lots of really good info here. Remember swaybars dont make your ride more "stiff" they reduce roll.
The Tarett rear bar has 4 holes for adjustment and on its soft setting is softer then the H & R. Rear bar installation is an easy DIY project, Front bar is considerably more difficult. The "Article" section has a post giving general instructions, I found it a little more difficult then the article described and definitely you want to use a lift.
