I'm not a racer and I tend to go pretty easy on my cars. Maybe I'm the only one in the world who didn't think HPDE was the greatest thing ever. My brain just isn't wired for it and that's okay.
I'm researching pads for my 2011 Boxster S.
I typically run Akebono ceramic pads on all my vehicles, because they are smooth, silent, and have essentially no brake dust. But apparently they don't make those for the front of the 987.2 - only the rear. Centric makes posi-Quiet ceramic pads, but again for the rear only. Putting ceramics only on the rear would seem like a poor choice, since now the braking balance would be affected and the front wheels are going to be filthy even if the rears are clean. Why would they make rears only?
I've read about EBC Redstuff ceramics, but I'm pretty sure I don't have the patience to deal with screeching brakes for the first 1000 miles.
Any other options I'm missing?
EDIT 9/1/17 - DMN987S below had the right answer. Akebono ceramic pads are an option! You can use the older 986-style spring clips (Centric part number 117.37004) with Akebono ceramic pads (part # EUR917) on the front of the 987.2. These pads will not fit the front pad wear sensors on the 987.2 so you probably will have to run without the sensors in the front. The rear Akebono pads (part # EUR738) fit fine with no modifications necessary. The rear sensors are compatible. I am unsure if the rear sensor wires can be used for the front on a 987.2, but that may be a workaround, or maybe 986 front sensor wires may work?
