I took the car in for an alignment last Wednesday. When they finished they told me that the most camber they could get on the right side was -2.1 in the front and -1.6 in the rear. Interestingly this same shop told me the same thing about my GTI when I bought it there. I looked at their initial numbers and it was like -2.7/-1.9 in the front and -1.9/-1.3 in the rear. They maxed out the right side and made the left side match.
My gears were grinding the whole way home. It seemed strange to me that two different cars would have almost the same exact camber offset side to side. When I got home I could see a visible difference side to side. The top of the front tires were off by about 1/4". I decided to check the camber at home on Saturday using my digital angle finder again. I measured with the car pointed in and then pointed out in the garage. The absolute numbers changed by about .2 degrees depending on orientation but the offset was always -.5 on the right side. That pretty much eliminates the garage floor being the problem. I'm pretty sure that their rack needs a calibration. Crap!
There isn't anyone with a decent alignment rack open on the weekend around here and I had a track day at Laguna Seca on Monday. I wasSOL as far as getting another shop to take a look at it so I decided to take a look at it myself. On the rear end the left side was pretty much maxed out on negative camber adjustment while the right side was almost at the minimum. I measured the toe with a pair of straight edges and tape measures. Then I adjusted the right side so the camber and toe adjusters matched the left side. I wound up with +.4 more camber and the toe stayed the same. I did the same procedure to the front. The top of the right strut was clearly 5/16" out farther than the left. I made them match and then readjusted the toe. I took the car out for a test drive and it was dead nuts straight. I remeasured the camber in both directions again and it's much closer. Maybe .2 degrees variation L/R now. That should be good enough until I can get it to reputable alignment shop.
I think its around -2.4/-1.8 F/R now. It looks like I'd need to add adjustable toe links on the rear to get any more camber.
