My GLK350 has a piano black surface in it surrounding the shifter (not a Porsche I know, but I believe some of the Porsches have this same surface material in them). It's constantly dusty and a nightmare to take care of--I use only microfiber to dust it off, and yet there are still surface scratches in it that are obvious when the sunlight is showing on the trim
Is there a proper way to clean this surface and/or remove the surface scratching that is already present? I've thought of using a Meguiars product I have that removes spotting/scratching on the exterior paint surface--would this be OK to use on the piano black material or a bad idea?
Try a product called "Luster Lace Detailer" (a google search will present many sources). It's a spray and can be used on metal, glass, plastic - virtually any surface. No worry about overspray and it makes all surfaces look good. I especially liked it on the piano black dash in my '08 Miata. One tip, shake it well before use and frequently during use.
The piano black material is just painted with maybe a clear coat. I used to use the Zaino PC swirl and haze remover on my black birdseye and on my aftermarket carbon shifter surround and then waxed it. The Meguires should work too.
