Hey guys wanted to make a thread about the infamous clutch safety switch that failed recently on my car . Seems like it’s a common problem you get in the car , press the clutch, turn the key and it won’t start. The dash will say “depress clutch” . It’s a small white switch under the pedal .
just wanted to show you a quick $5 fix that will save you from being stranded. Reach under the pedal and pull off the 2 wires from the switch terminals and insert the female ends of the wires onto a standard fuse. Works every time now until new part comes from pelican.
alternatively you can hold the key to start for 30 seconds but this won’t always work.
269437
PCA Nat'l DE Instructor
Clever (hack) solution! Thanks for sharing this.
Sent from my SM-N910V using Tapatalk
Nice! I replaced mine a couple of months ago on my '05 BS. That thing was an absolute @#$%! to rotate and install....
Discussion Starter #4
Fixed it today ! What a pain of a job , took 10 min but I had to use a pair of pliers to rotate a torx10 stubby bit to get the 1 screw out ..no room to even fit a ratchet just had to macgeyver it...didn’t have to remove anything else. Note the different part number on the failed one . I assume they changed some things , it works fine now.
269454
Been a while since I replaced the pesky switch but as I recall it was nigh impossible to remove the switch directly. Instead I removed the bracket it attached to. Removing and replacing the switch was then easy.
