1 - 15 of 15 Posts
Dealer quoted me $700.00 to install a set of headers, said it was a "Big Job". Should I look elsewhere?
We quote and typically charge 4 hours to prepare for some cushion or any setbacks. the additional 3 hours seems a bit excessive unless it was an entire header and muffler system UNLESS this system has flaps. If this is a switchable flapped system, then unfortunately you need the 3 additional hours for wiring and the usual.
Just had Fabspeed put their sport headers and poliched tips on my 981 CS and kept factory muffler. Took 4.5 hours start to finish, but there was a 1 hour lunch break for the installer in there, so 3.5 hours total. I don't have my invoice handy, but I think it well under $400.
I was charged $170 in a local shop. Was worried they would charge me over $400 and eas very pleased with the price. I gave $20 tip to the guy since I felt guilty for the low price, haha
Headers? Super super easy to do on stands. 7 hours is rape.
Reactions: James III
BGB turned me onto GPS in the Boston area to installed Cargraphic manifold & muffler, IPD plenum and BMC filters.
All done in 5 hrs...
I watched my guy install my Fabspeed headers in less than two hours.
Lemmon,which bolt is a pain? Do you need a special tool?
wow.. we charge 250 here in Schnell.. wow.. it only that one stupid bolt thats i a pain...
lemon
where are you located? My understanding is a header install on a Boxster/Cayman should take less than 2 hrs. and I would ask the dealer for their hourly shop rate. $ 700.00 is way to high.
Agreed, not a big job. Less than two hours labor to do this easily by a competent mechanic. However, give them an extra hour to let it cool off, test for leaks, and give a quick test drive. Three hours at $150/hrs for dealer rates and you have $450 or $500 out the door. Your independents are of course much cheaper as has been demonstrated here.
Is that on 987? Is it cause you can't get a socket on it?
there is one in the middle, on each side.... its like 1/32 turn at a time.. and its a 3 inch bolt..
Lemon
1 - 15 of 15 Posts
