1 - 3 of 3 Posts
Hi, i am interested in changing to the wevo transmission mounts and updated oem engine mount as recommended on the wevo site. I like to work on my car as much as possible but i don't have a garage so would be working outside in the street with the car raised on blocks. Obviously i don't want to do this if its dangerous or likely to be too much hassle with the space I'm confined to. Could anyone whose has done the work give a view if this is a good or bad idea? Thanks
As long as u can support the motor and trans as you take off each mount, then yes, it shouldnt be a problem. Do oneremove replace at a time and youll be ok.
1 - 3 of 3 Posts
