Hi - I've been putting a summer/track wheels+tires combo together:
used 996 turbo twist wheels, 8" and 11" widths, front and rear,
used pirelli P-zero fronts - I think they've sat a year or more, -- 225/40-18s
new Sumitomo HTRZ-II rears (Tirerack.com has great prices on these) - 275/35-18.
the 11" rear wheels have an offset of 45 - so I found a used set of 15mm spacers and use these w/ the rear wheels + tires. They fit w/o rubbing but it's tight.
using 5mm spacers on the front.
both the fronts and rears are summer / high-performance tires. I had been using all seasons in 235, 265 / 40 - 18" sizes.
So. First drive and the new setup is twitchy, really twitchy and I could use some learned opinions as to what may be going on. The rear seems well planted, and the front responds immediately to even the smallest input - sometimes to a too-great degree.
At speed I had to back off because my corrections for wind, road were only tossing the car worse than what I was trying to correct for. up to now the cayman was very easy to drive fast.
my pet theories -
1) the fronts came w/ the wheels and seemed pretty hard. maybe they need some recent miles to soften up. dropping the pressures to 35 -warm seemed to help.
2) the rears are new and not broken in at all ... probably started this drive on whatever the tires come coated in from manufacturing. That said, the problem seems more front than rear.
3) taking some sweepers at speed, PSM would activate briefly - I have a good match on tire diameters front to back, wonder if the rear's wider track may be fooling the PSM.
4) maybe I am just sticking that much more ... but I still couldn't drive smooth enough at speed w/o the car starting to hunt back and forth.
5) maybe one of the used fronts is separating or has some other serious problem.
Thoughts?
the first thing I'm going to do tomorrow is put my all-season fronts back on and see how it feels. If there's a significant improvement then I'll probably have to pop for 2 more new tires.
thanks,
-PM
my pet theories -
Thoughts?
thanks,
-PM
