Silly question. I got a Ctek time to go CT5 charger the other day and wanted to hook it up to the car. It doesn't come with a cig lighter only the terminal connections.
My question would it be ok and safe to leave these terminals plugged into it? It comes with a quick disconnect from the charger. This would make it infinitely easier and more convienant that I can just unplug the quick disconnect vs having to take everything off the car. The alligator clips are bulk and I cant keep the cover on the frunk on it or close the frunk properly.
(after taking a pic I realized youre suppose to use the negative on the wiper stalk)
Last question is, the oem battery is AGM, but im unsure what mode I should use. Standard or AGM for charging
Normal battery program14.4V/4.3A. Use for WET, EFB, Ca/Ca, MF, GEL batteries and many AGM batteries
.AGM battery program 14.7V/4.3A. Use for AGM batteries
Do our cars have the higher 14.7 v? or Should I use the normal mode which says compatible with "many agm batteries"
