1 - 3 of 3 Posts
I've got a clear "ding" on the clear bra from a rock. It did it's job in protecting the hood, but now a clearly visible elevation. Every time I wash the care I reach this area and wonder if there is anything I can do to smoothe it out. Any suggestions that I could do myself.
thanks
Enjoying the drive.
Mine is under a warrenty. If there is a problem with it or it is damaged, the company replaces or fixes it. Look into ti with the installer.
I'd say it depends upon how bad or deep the ding is. If the film is not penetrated all the way thru, I would try a heat gun. I've used a heat gun to 'heal' the many abrasions and little dings I've gotten from track events. I use a pretty high heat setting and move the gun around being careful not to get the film too hot - you can bubble or visibly melt it if you concentrate the heat in one place for too long. If you are patient, it's amazing how well this works.
1 - 3 of 3 Posts
